timsheehan
Thread starter- Joined
- Apr 30, 2009
- 5
I have an aluminum 1988 Starcraft SFM160 in really great shape with a Johnson 48 SPL motor, same year I think. Appearance of motor is excellent. I've had problems lately with the idling after trolling a while. Plugs look like they're getting oily. I've changed the gas line recently, cleaned the filter screen, hooked it to a portable tank instead of inboard tank, rebuilt the carbs (even though after using it for 10 years they looked clean as a whistle when I took them apart), put gas dryer in the built-in tank (even though gas was treated before wintering), put in new plugs, and read the heck out of these forums. One last thing is to go through the carb adjustment procedure in the top secret file but the advice is for a v-4 engine or a single carb engine and as clean as the carbs were I'm not sure mine needed adjusting, so I haven't gone there yet.
So my question is two fold, should I keep this engine because you know it can be fixed to troll trouble free and your advise to fix it is...... or if trolling is important then consider buying a new motor of which you can advise me which make and model was designed to run trouble free for trolling. I think I'll stick to the 50 HP range if new is what is recommended.
Also went out this evening and tried pumping the bulb when the engine sputtered at idle (got the idea from another forum thread) but that didn't work.
Thanks for any advice given....TIM
