I have a 1993 johnson 48 and while going full throttle it suddenly went down to about idle and then would kick back up to normal. It then went back down and stayed. I pumped the bulb while running full throttle and it made no difference. I pulled the boat out of the water and clean the carbs that were already clean just to find that wasnt the problem. When i put it back in the water and cranked the motor it idled rough until i pulled the lower plug wire. How can my motor run smooth or better with the bottom plug wire pulled. Could this be a powerpack issue? This motor has never compared to the speed and power of my old 1983 evinrude 50 with the same prop.
