Johnson 4hp Lower Gear oil Specs
jeep187
I have a 1994 Johnson 4hp Model # J4RDHERE with Foward and Reverse (I think it's the deluxe)
How many ounces of gear oil go in it? I called numerous dealers and get all different amounts.
Thank you in advance, John
Vic.S
Re: Johnson 4hp Lower Gear oil Specs
You fill it by pumping oil in through the drain hole until it flows from the level hole.
It takes as much as it takes but it looks a very similar gearbox to the one on my slightly older 6hp. That holds 325ml. I expect yours will be either the same or a little less. (quoted in ml becase they are international and the same the world over. US ounces may be different to UK ounces)
Dont forget to use new washers on the drain and level plugs.
jeep187
Thanks for your help
