Re: Johnson 5,5 compression
PSI will vary a lot from different guages and techniques, ML.<br /><br />On that engine one might get numbers as low as 60psi or as high as 125psi, both on a healthy engine.<br /><br />The important number is the difference between the two cylinders when measured in exactly the same way. They should not differ more than 15%.
