Johnson 6-8 hpmade in 1980'
raczekp1
Hi.
maybe someone did some play with pistons taken from Johnson 6-8 hpmade in 1980'
i lost notice how may needles contain conecting rod evenlope on crank shaft?
gm280
Isn't there a cage for the needle bearing to fit into? If so then the number of positions would be your answer...
raczekp1
no, there is two linear half evenlope( put together comes as one) and 29 or 30 needle
Honorary Supreme Mariner
Those needles are easy to lose.--------------Just put 2 of those engines together.------Will look in the manual tomorrow to see how many are in there.----------30 seems like the total If I recall.
raczekp1
middle bearing contain 30 needles but not sure how many should be on connecting rod,
f you can scan manual and send me pages some as pdf file it will be nice.
Mod edit: Please no personal info on open forums. If needed, please use the PM system. Thanks.
raczekp1
i need some help once again with this motor.
how many needles is in center bearing.
29 or 30?
