Bullie
Thread starter- Joined
- Dec 20, 2014
- 300
The 15 is back up and running! I couldn't have done it without you guys. I will put it on the water soon to check everything out. It started on the 3rd pull and purred like a kitten. I did notice the stream was kinda sporadic and weak so the next project will be an impeller.
The thermostat gasket came in for the Johnson 6 too. I will get to work on that soon. I guess a razor blade would be best for scraping all the gasket goop off?
Thanks again for your help. Great advice without being talked down to...y'all made it easy.
