Swivelhart
Thread starter- Joined
- Nov 5, 2008
- 185
OK. Just bought a boat and love every bit of it. Took it out yesterday for the first time on the lake and it ran strong for 15 minutes and then started to die as if starved for fuel (you know the bogged down sound with loss of power). I had my wife squeeze the primer bulb on the tank before it quit and then vrooooom right back up to speed for another 2 minutes then boggg. "Squeeze the bulb wifey" vrooom back up to speed and so on and so on! What is the deal with that? I noticed after getting the boat home and checking the tank that I forgot to loosen the vent screw, even though it was not super tight! WOuld that make a difference. The hoses from the tank are pretty stiff as well even thought the primer bulb is soft. Does any of this have anything to do with the engine issues. Also where in the world do I find the motor identification number on this thing? I only found some numbers on the cylinder head and freeze plug...Help! Need to identify motor in order to get parts.
One more question while I'm at it! Can I put the portable tank in the front of the boat and just run a length of fuel line from the primer bulb to the outboard?
