Good day I have a problem with my engine The engine starts when cold with no throtle and runs at low revs OK. when I power the engine up the revs increase then start to drop, when I power down the engine stalls I have cleaned the carbs fitted new floats and float valves and all gaskets. The fuel pump has been replaced and the primer ball stays hard. The ignition coils have also been replaced as the old ones were cracked, and a comlplete replacement impeller unit fitted Could someone please point me in the right direction
