johnson 6hp carb problem
slate1234
Hi all I have removed the carb from a 6hp Johnson (J6BACTA) ready to fit a carb kit thats on it's way but I cant remove the emulsifying tube as it looks damaged and won't move so 1: how do i remove it and 2: I have a old 7.5 carb could I remove the emulsifying tube from this to replace the 6hp one thats chewed up.
and any links to the rebuild would be much appreciated,
Thanks
F_R
Honorary Supreme Mariner
Re: johnson 6hp carb problem
Don't know. We didn't have a 6hp here in USA that year, so I can't look it up. You are speaking of the main nozzle? It may be that it doesn't come out. Sorry, I can't give an intelligent answer. Perhaps somebody in your part of the world will see this and know more.
boobie
Those tubes are part of the upper carb body and non replaceable. If you can find them in a parts book, please let us know.
slate1234
ok so someone has tried to remove the one in mine and chewed it up so could I therefor use the 7.5 carb body and remove all parts from the 6hp and put them on the 7.5hp its the same shape and size but the throat on the 7.5hp seems wider
Vic.S
Why not contact one of the UK parts suppliers, telling them the model number.
Oakley marine aka Outboards direct in Brighton :: OutBoards Direct :: are very helpful and will be familiar with the Belgium made models
Wills Marine in Kingsbridge, Devon are also good for mail order spares. Willsmarine
The YBW.com forums are also good for help and advice in the UK http://www.ybw.com/forums/index.php
slate1234
had no joy on the above forum any help would be welcom
