Re: Johnson 6R-72D Maintenance
Yes, read the thread here:
http://forums.iboats.com/showthread.php?t=158086
Here's my short list:
Take the spark plugs out and spray (squirt bottle) some 50:1 gas/oil mix in the cylinders.
See make sure you can rotate the flywheel easily be hand (clockwise).
If it rotates easily, then check the compression using a compression tester. That motor 65-85psi while pull starting would be OK as long as it is even between the cylinders. If it does not rotate easily, then don't force it. Spray some penetrating oil in the cylinders and let it stew for a day and try again.
If the compression checks out, then use a spark tester to see if each coil puts out enough to jump a 1/4" gap. If there is not spark on both cylinders then you'll have to pull the flywheel.
If you do have both spark and compression, then try to start it in a barrel or trashcan with fresh gas, 50:1 mix.
If it starts, then you're not quite done. If you don't absolutely know how old the water pump impeller is, change it.
Change the gear lube (85-90W marine gear oil). DON'T TAKE OUT THE PHILLIPS HEAD SCREW!
Change out the nylon washers on the vent and fill screws while you're at it. Check the gear oil after the first run to see if water leaks in.
