Johnson 70 vro no drive to prop
lazyb0y
Hi, I have a Johnson 70 think it"s an 1989. I was coming back in after a trip and a knocking noise started coming from the engine. I layed off the throttle and the knocking stoped for a sec and started again then kept getting worse to the point of where there is no drive to the prop. When I select forward or reverse now there is no continuous drive just the odd crunch. Has anyone got any ideas of what this might be and also how to go about checking what"s wrong? Thanks in advance
Honorary Supreme Mariner
Drain the gear oil in lower unit.----Likely you will see metal bits come out.
