johnson 70 weak spark wont start easily
desertratz
I have a 89 70hp johnson that has been giving me intermittent stalling. It finally would not start so i have been testing stuff. It has spark but very weak. I suspect the power pack or stator but how can i test to make figure out which one, without a DVA.
jakedaawg
you really can't. I suppose you could do the resistance checks on the coils and also on the stator. That might show a glaring error but it certainly is not foolproof. I have had many stator windings whose resistance was considerably out of spec but still produced the necessary voltages.
Faztbullet
Check the stator as it is what charges capacitor in pack....weak in = weak out
Check the STARTER MOTOR too.-----Get battery load tested.-----When these motors crank slow you will have ignition problems !!
desertratz
thanks for the responses guys, so far i have ohmed everything that i can and is within spec. coils, rectifier, stator, timer base. starter is cranking pretty good spining the motor over at about 800 rpms. one thing i noticed that i thought was a little weird is that while running the motor voltage at the battery is reading 16 volts seems pretty high.
