johnson '82-35 hp
roscozen
engine starts and idles thru marina just fine. when i give it throttle in gear it won't respond. i gave it throttle manually after disconnecting linkage and same result.i get good rpms in neutral, tho. so it won't perform under load. anyone have an experience like this?
tashasdaddy
Re: johnson '82-35 hp
99% dirty carbs, but check your compression and spark with a spark tester.
