SteuryLover
Thread starter- Joined
- Nov 19, 2008
- 191
Hey everyone, thanks for the help so far. I finally declared defeat with my low RPM issue and dropped the boat off at a local shop. I have not taken the boat out yet, I will do in the morning. Here is a quick recap.
Boat will not go above 3000 RPM while under load in the water or on the dyno. I attempted to rebuild the carbs, changed old cracking coils as well as a # of other parts that were replaced as the problem. Having faith in everything but my carb rebuild I could not solve this issue on my own. So i dropped if off. This is what they said.
Rebuilt Carbs - new gaskets and so on...
Checked timing
Check linkage
Put in in the water while still on the trailer they were able to get it to around 3000-3400rpm
They came back, put it on the dyno and they said they got 5000+ but did not have an specific # for me.
They claim motor should be good to go, needles to say i am a little nervous about the test run. If it runs correctly (5000+ RPM) I will feel as though I am dreaming! So here is my question
The boat would only go 22MPH at 3k RPM before I brought it to the shop. The boat would plane (18' center console deep V 1200lbs dry) no problem but the cavitation plate was under water. First off, will the motor raise with speed if the motor actually gets up to correct RPM and speed, hopefully 35+ MPH. Second if it is still a couple inches under water will it decrease the RPM dramatically say 1000RPM, or just slightly say 2-300 RPM? Thanks for everyones time on this.
Checked timing
Check linkage
