SteuryLover
Thread starter- Joined
- Nov 19, 2008
- 191
Hello to everyone in the iBoats world. I have yet another problem with my 1993 Johnson 88 SPL. I have many other posts on other issues that have since been solved, thanks to everyone here. So here is the new one.
A few weeks ago after replacing the water pump I was under way and the boat started acting up after about 10 mins of running. Stopped, pulled the hood and noticed salt water everywhere. Look at the back of the motor and saw that one of the water hoses going to the head plate sprung a good leak. I am assuming this was hidden before because of the previous weak water pump. Well, ran back to the house to see what we could do. Replaced both hoses and no water problem is fixed. Now here is the problem created from that again I am assuming.
Now the motor is having issues starting no matter if its in the water or on the hose. Dual batteries fully charged, cranking fast. It takes a lot of fiddling to get it finally going on what seems to be 2 or 3 cylinders. At one point the motor in the water ran perfect, roared like a V4 Johnson should. Then intermittent RPMs again. Run to 4200, then 3000 then 2000 then 4200 again.
New coils on all cylinders, new OMC power pack, new Champ 82 plugs, new rectifier, fully charged battery. One dry plug, 3 wet ones after running. Recently rebuilt carbs, perfect compression just done, fresh pre mixed fuel, new fuel pump, new water separation filter, new fuel ball recent timing and link and sync.
I do not think it is fuel, pressing the primer will do nothing while running. The fuel ball is rock hard and all filters clean.
Could the good amount of salt water have ruined the stator? Anything I should check after the water sprayed down the inside? Any ideas here is appreciated. Thanks for everyone's time.
