Johnson 88 stuck powerhead ** please help **
zman_99
Hello. I'm trying to remove the powerhead from my 1989 Johnson 88 special. I've got the lower unit off, and all the nuts and bolts removed except for one problem. I was able to remove the nut from the port side rear stud, but the stud seems to be stuck due to corrosion. When I lift on the powerhead, it starts to separate from the exhaust housing but that stuck stud prevents it from coming off :confused:. Any help would be appeciated!
