Johnson 88 to a 115
surrender
My 88 special lost two rings(think I found out why) and in my search for a new block(broke a small part when removing powerhead) I found a 115 block with a bubble back exhaust. When I rebuild will this result in a 115 hp motor or do I need to upgrade my carbs to achieve 115 hp.
Bob_VT
Re: Johnson 88 to a 115
Carbs, reeds, exhaust leg....there are many differences. Yes, you will benefit from the larger block but to say you have an actual 115 is really too optimistic. Let's just say you will have a healthy 88 ;)........ you should go for the carbs if you can find them.
surrender
Thanks Bob. My carbs are good but can I change out the orifices(non adjustable jets) instead of the whole carb?
boobie
No. Carbs have different size throats.
