johnson 9.5 1970 starter spring
knschoenborn
My Johnson model #9r 70c has a problem with the hand starter. It broke when I fell back while pulling it. At first it would still rewind if I took the hood off and manually moved it a bit. Then after a few pulls it wouldn't rewind at all. I took it apart and found the tip of the spring retainer was broken off. After weeks of eagerly waiting the part came in and I installed it. Now I'm back to the beginning. It will rewind only if I tap it a bit and help it along. Anybody have any experience with this type of hand starter. The spring retainer cost 45 bucks so I'm really afraid to break it.
jim_in_day
Re: johnson 9.5 1970 starter spring
did you put a preload on the spring? if there is no preload on the spring, it will not rewind properly, especially at the end
knschoenborn
Originally posted by jim_in_day:<br /> did you put a preload on the spring? if there is no preload on the spring, it will not rewind properly, especially at the end
