johnson 9.5 fuel pump assembly?
drrtydog
I took the fuel pump apart and not sure how it all goes now and iv looked through the manual and there is nothing that i found that shows how it goes back together. Does someone have a pic of this or mabey give me a good right up of the order of the parts?
Rick.
Re: johnson 9.5 fuel pump assembly?
Your not the first person this has happened to. Have a look at this site and down near the bottom there is an instruction for rebuilding a fuel pump. I don't think it is exactly the same as yours but hopefully close enough that you will be able to figure things out. Best of luck. Rick.
http://www.sschapterpsa.com/ramblings/Ramblings.html
drrtydog
Yes that is what i needed. Thanks
