johnson 9.9 hp coil obselete ????????
ewan777
Hi , i am still having no luck at getting my boat on the water , it has been sugested that the outboard motor that i have now , which once it warms up cuts out , has a faulty coil . the motor is a johnson high thrust , 9.9 , 1997 , fourstroke , BJ10FRELUA , coil number 0584451 but this coil is aparently obselete now ?? has any one else had this problem ? does any one know of a coil that will do the same job or where i can get the origional ?? if no one can help i will have to dscrap the engine please help !!!!!!!!!!!
jasper60103
Re: johnson 9.9 hp coil obselete ????????
Yea, looks like after market (CDI, Mallory, Sierra) is your only option, unless a dealer has old stock on hand. I bought CDI coil and it worked fine. Others have used after market products with success as well.
http://www.iboats.com/mall/partfind...gd_poid=334772&gd_row=53&**********=160377076
Rick.
It might just be me but would you recheck your model number. It just doesn't line up with anything or it is always possible it's my limited metal ability. LOL. I've not heard of 9.9 coils being obsolete but I guess that is always a possibility. Best of luck. Rick.
ezeke
BJ10FRELUA is fifth in the list of 1997 Johnson 9.9 models on the BRP/Evinrude parts catalog site: http://evinrude.cust.shopatron.com/
AlTn
unless I'm missing something...the parts list shows it as "not available"...surely a dealer somewhere in the US has one...can dealer's put out a needs request sorta like the old junkyard hot line?...if not, I'd suggest seeking one in whatever brand outboard make it was before it was rebadged...or go to cdi's website and send them an email question...otherwise, it's salvage yards and hope...best of luck
jasper60103
Just the OEM coil is obsolete. CDI, Sierra and Mallory still sell them.
AlTn
wellllllll....cdi's site says to contact them as they can repair it....this particular model no. shows a single coil with 2 lead terminals...so it's a single coil for both cylinders..part no. 0584451...the other suppliers don't list that no. as an original part no. for their replacements...shop2.evinrude.com is the source I used for this info...btw...look at the cost for an ignition module for that model....wow!
bankerjohn
My motor uses the same "wasted spark" ignition coil ... bought one last year for my motor, but it didn't solve my problem. Both cylinders fire on the compression stroke and on the exhaust stroke ... or at least that what they're supposed to do, assuming the coil is given correct instructions by the (absurdly expensive and obsolete) power pack.
clanton
This coil not avalable from CDI, at this time. Info from therir site. Try Suzuki, same year and HP.
clanton
This coil not avalable from CDI, at this time. Info from their site. Try Suzuki, same year and HP.
ewan777
hi thanx for your input , do you have the website for cdi as i cant find it
bktheking
AS per their site:
R prefixes on part numbers indicate Repair and Return items. Send your original unit to CDI Electronics and our technicians will repair the product and return it to you. The unit under repair is received, de-potted, repaired, and potted within 15-30 working days. (knowing this time frame helps to keep your customer informed).This feature is yet another service of CDI Electronics helping to keep your boat on the water.
You need to ship in for repair.
http://www.cdielectronics.com/AppGuide.aspx
AlTn
Ewann...I goggled suzuki outboard motor parts and brownspoint.com shows a coil for a 1997 9.9 suzuki with 2 plug wire posts..there's a parts breakdown with pics for that motor...dunno if it's the same or not...maybe someone on the yamaha/suzuki forum can help
AlTn
For the record...in the event anyone comes across this thread...the coil's part no. for his model no. of engine is 584451...not 582106 nor 582366...for which the link posted is a replacement...his engine uses 1 coil to fire both cylinders,not 1 coil/cylinder...if I'm wrong, correct me...enuff already
jasper60103
Oh, I see. My bad. Thanks for clarifying.
bktheking
Right and according to OMC's site is in NLA which is why you need to ship it to CDI to have it repaired or have your dealer make a call to OMC in the west coast , they have an NLA parts division out there.
So far i've called 3 out of 4 dealers here in town, nadda.
ewan777
thank you for adding you information i cannot find the coil at mallory or sierra or cdi if any body has any better luck please let me know . am sure i will get there eventually with all this help . thanx
ewan777
hi yes compression been tested , i have a spark until it cuts out the no spark ie. coil problems because it wont start until its cooled down . thanx i have e mailed cdi in england to start the ball rolling .
