Re: Johnson 90 hard starting and lack of power
Sounds like it's all jacked up.<br /><br />At least needs a "REAL" carb cleaning, but check and make sure the fuel is getting to the carb well.<br /><br />Also make sure you have the cold start procedure down and understand how to choke the motor.<br /><br />It's not bad mechanics process to go from there and also do a compression check to determine the soundness of internals.<br /><br />Then after going over those essentials if drivabilities still exist start running electronics diagnosis.
