BallisticRenegade
Thread starter- Joined
- Aug 31, 2012
- 27
I purchased a Sierra Carb Rebuild Kit 18-7046
I have everything cleaned up. Pulled all the Jets and Orifece and cleaned them. I am ready for reassembly. None of the gaskets that came with the rebuild kit seem to go any where. I figured the Gasket plug o-ring (leading to the main jet) would get a replacement in the kit but there is only 1 of them this size in each kit. The o-ring to the idol jet is non existent on my model as it uses a lead shot plug. None of the items are labeled on the website or in the instructions.
They include 8 rings or round seals in this kit and the only one I can see that I will use is the Needle and seat gasket.
Does this sound correct?
Question #2
The book calls for a core plug adhesive but the kit instructions make no mention of this.
Question #3
Is there a recommended way to seal the new gaskets? nothing is mentioned about this however I have always finger tipped a bit of oil on a gasket to help with the seal in the past.
Question #2
Question #3
