stkonmyboat
- Joined
- Mar 1, 2009
- 1
I recently purchased a boat with a 99 Johnson 90 HP motor. I after going out a couple of times it started to bog down after an hour. I tried to make some changes that I thought would fix it. I emptied and cleaned out the fuel tank. I also changed the filters and plugs. Again went out ran for a hour good then lost power after a hour. Full throttle runs at an idle speed.
I brought it to my mechanic and he checked the carbs and engine compression. All was good. He also checked the fuel pump. He said it was all ok. He did change the thermostat think this was causing it shut down.
I took it out again and it happened again. After a hour it lost power. At full throttle it moves at idle speed.
HELP. I want to enjoy at least 2 hours out on my boat at one time.
Any ideas what can be wrong???
