dethloff04
Thread starter- Joined
- May 30, 2007
- 4
Hello Everyone!I purchased a used boat which came with a 86 johnson 90 vro.Motor cranks right up but i have an overheating problem.So far i have:
1.)removed the thermostat housing(sand was in the housing, which i throughly cleaned and replaced with two new t-stats.
2.)I then cranked the motor up without the hoses connected to the t-stat housing to see if im getting flow through the cylinders=water comes out of each side
3.)didnt check impeller, only because the pisser is peeing good and there is water going through the water passages through each side
With the t-stat housing replaced the left side cyclinders dont overheat but the right side does.I checked both of the new t stats to make sure there opening in a pot of water on the stove.I steems like the water flow is getting blocked somewhere, but i dont know where because im getting water through the pisser, through to each side before the t stat housing, but the right side seems to become more pressurized after water fills the tstat housing and wherever else.
ANY ADVICE WOULD BE GREATLTY APPRECIATED~!!!
