wakeout
Thread starter- Joined
- Nov 28, 2005
- 58
Last weekend I took the boat out, had a hard time getting it started
which it has all ways been hard (because of it being cold) finally got it
started and we took off a little ways and it died, started again went
a little further gave it half thottle started to take off to get on plane
then it slowed back down and it keeped doing this. At one point the rpm's
went from 3000 to 4000 and I pulled the thottle back. So I loaded the boat
went home, pulled the cover and checked the plugs and they looked
good, I then hooked up a water hose and started the motor it ran fine
when idle and gave it more thottle and it seemed to run fine. I found that
the little hose that connects to the pisser had cracks in it and there was
water sitting inside, so I cut hose just above the cracks and put it back
on now water shoots out in a solid stream. Stoped at an auto parts store
and picked up a can of seafoam, got back to the lake the boat started
with no problem, after the seafoam started working it ran better, but
at 3000rpms I should be going 30-35mph. It was only running 20-25mph
at 3000rpms.
Would this be happening if there has been water in the carbs or is it a more
serious problem?
at 3000rpms.
serious problem?
