Johnson 9hp problem
capitan
Re: Johnson 9hp problem
I just swapped them today, that's when i managed to get it running, probably coincidence. my not being a pro and may not recognise a worn needle i just swapped it to try it in case the previous owner may have changed it or something. I still have the other needle!
Rick.
Well I'm glad to hear you've retained the original. I would put the original back in and like I said, do the carb. cleaning and a new kit. Needle valves don't come with carb. kits but I have been able to get them as a seperate item at my OMC dealer when needed. Take a very good look at the point of the needle. If you can see a ridge or that it's bent or any wear marks you should try to get a new one. It is very important to the success of getting you motor to idle. On the other hand, it should last forever so don't change it as a maintenance item. Once you get the carb. done I think you will be up and running. Let us know. Rick.
capitan
The so called original needle has a blunt flat point and the others i have have sharp points to them, another reason i tried a different needle, does this sound normal?
Rick.
No it isn't normal. Probably caused by being turrned in too tight or dropped on the floor. Rick.
capitan
So how does it work, do i get a number off the carb and that will tell me exactly what type of needle that should be in there and then order a new one?
Rick.
If you have the model # for your engine that should work at a dealer. Having the carb. number might help but then again it might be the part # for the bowl that you see. Give it a try and see what the dealer says. Rick.
