rammerjammer05
- Joined
- Feb 17, 2011
- 52
1988 Johnson 175hp. Model#J175STLCCM.
I need to remove the bearing housing assembly to get to the o-ring that is behind it i found out that it is leaking from behind the housing.. I can see the 4 bolts in the bottom of the housing and i have removed them. My question is can i just use a 2 jaw pulley puller to remove the housing or will i need to get 2 long pieces of all thread and attach them into 2 of the holes i removed the bolts from and then use a flywhell puller to remove the housing. I plan on replacing the 2 oil seals in the prop shaft while i have it removed so.
