Johnson boat question/outdrive
phatmanmike
Re: Johnson boat question/outdrive
seriously, why would you want that boat?<br /><br />are you bored?
Mod2
Moving to Inboard Engines Forum.
walleyehed
Well I got cut off while typing in the other forum, but my suggestion would be to leave it to somebody who has lots a money to keep that outdrive operational...
cmyers_uk
How do the exhausts keep cool?
2cycle
Thanks everyone for the advice/thoughts. Mike, don't really know a good reason why I would want that boat, but I'm sure it would be a good cure for boredom as it would probably require a lot of attention. I never knew that Johnson had manufactured boats in the past. Dunaruna, I enjoyed looking at the sight and a novel piece of boating history - Thanks! Walleyehed, I think I will follow your advice...
tommays
at least its not the 2 cycle sterndrive<br /><br />tommays
KaGee
Yep, that drive looks to be electric shift... some of those parts are slowly turning up NLA (no longer available). Even used prices on Ebay are going through the roof.
bomar76
At the current bid of $205 it's $500 overpriced ;)
2cycle
The boat went for $329.00....or $624.00 overpriced according to standard bomar 76 accounting/appraisal procedures..hehe.<br /><br />Any guesses as to how fast that 350 will push that old tri-hull? 40 MPH?
bomar76
Assuming it ran and moved (not likely) not fast enough to avoid the water cops and the reaming you'd get for using dry headers in an enclosed engine compartment....bet everything else on that tub's engine was non marine too
