Re: Johnson choke-primer solenoid
BQ.... With that RED lever in the opposite position, fuel will flow freely through it and into the leaf plate (reed) area with every pulse of the pistons.<br /><br />The reasoning for being able to turn it in that direction is if in case the battery goes dead.<br /> <br />Turn the RED lever so that it faces away from the solenoid body, then pump the fuel primer bulb a few times. This allows fuel to flow into the intake manifold area (same as what a choke would do). Now, return that RED lever to the automatic position as I mentioned previously.<br /><br />Turn the key to the on position, have the engine in neutral, wrap the starter cord around the flywheel, then pull it through without hesitating ie... get that rope clear off of the flywheel.<br /><br />The engine should start. You may need to leave that RED lever in the manual prime position until it starts.... but try the method above first.
