upnorthzx10r
Thread starter- Joined
- Aug 28, 2009
- 2
I have a 1983 Canaventure runabout....with a 70 hp Johnson on the back (1983) The boat and motor are in tip top shape....hasn't let me down untill recently. The throttle box has an emergency lanyard switch on it....(which is missing, its only a little spring loaded button that is showing). The control box sits kinda close to my hip when driving the boat....one day we hit some pretty rough water and were getting bounced around good and my hip hit this button, which killed the motor....after a few minutes i sourced the problem...and pulled the button out and it fired right up and we were on our way again...but a few times it wouldn't start with out fiddling with this button...and its to a point now were it wont even start....it just keeps turning over and over but wont go...and if you hold the button in while cranking...it sputters a bit but just wont go...no amount of workin the button in and out will make it go. Haven't tried manually starting the motor yet. Is there a way to by pass this emergency switch in the control box. I know this is the problem...the motor was running great up untill i hit the switch. Thanks for any feed back.
