Johnson Cooling Blockage (picture)?
Sureshot
Hey all, I have a J50PLSSM. With the head off I noticed what appears to be a blockage of one of the water passages. It's where the warm water flows out of the head on its way out of the motor. The other exit hole is clear. The engine ran fine with this apparently, no overheats and always had a good stream out of the tell tale. Anyway, any reason why this exit hole should be blocked or is this just some corrosion / etc. that needs to be dealt with. As always any advice appreciated.
orbanp
Re: Johnson Cooling Blockage (picture)?
Look at the mating part. Is there a matching hole to the blocked hole?
Have a look at the old gasket. Was there a hole in the gasket for that passage?
That should give you the answer!
Good luck, Peter
Sureshot
Yeah, definately should be 2 holes coming out of the head, through the gasket and into the power head. I'm assuming if left untreated this could eventually lead to an overheat?
phillnjack2
Ensign
serios blockage !!!!!
just have a little prod at it and see what happens.
it definitely dont look right.
like said abive if the mating surface to this has 2 holes then just dig away at it.
This engine would also need a good run in nitric acid or saltaway to clean out the waterways for sure.
phill
jim j geezer
I'd be less concerned with that blocked port and MORE concerned about what appears to my eye to be a pair of fractures just outboard of and above those 2 threaded mounting studs. Use a magnifying glass if you must.
Sureshot
I think I'll try and drill or cut out whatever it is blocking the left hole. The pic makes it look like small cracks but it's just shadows. Another question, head gasket was put on last year so it's nearly brand new. Can I get by re-using it or does this require a replacement?
boobie
I'd replace it................
Sureshot
Will do, thanks for the help.
