Johnson Enforcer 30 HP remote controls
brm 60
Hi, i'm interested if anyone knows whether the Johnson Enforcer 30 HP outboard (ML) 2004 accepts OMC or BPR remote controls. Currently the motor has been run using just tiller throttle/steering.
Appreciate advice if this engine accepts remote controls. thanks in advance
Willyclay
The shift cable and throttle cable brackets are NLA from BRP but you may be able to find them at a salvage place, ebay or make your own. The OEM steering link is available. CDI makes a wiring harness if you want to go totally-remote with electric starting since starters are available. Good luck!
brm 60
Thanks so much.....glad to hear it can be connected to remote controls...that was key for me. Don't need electric start....just steering and throttle control to be remote. Thanks again!
