jakedaawg
- Joined
- Jun 26, 2012
- 4,275
interalian there, he will get a note now.
So let me get this straight this guy screwed you then took your money and your motor . I would be getting my money back of i was you.. What he did was ridiculous.I do not have the 1981 engine available, mechanic said he had to trade the powerhead as part of the deal. Only thing I have is the carbs off the 1981 and the primer solenoid mounted in same place as the old spring choke. Okay to make sure I am understanding, I should not put 1/16 brass nipples straight into the bypass covers and let the primer put gas straight into there by using four intake hoses ( actually 2 hoses and split on each side with a tee for two intakes one on each bypass cover on each side) as this is what I was fixing to do. Instead I should drill into carbs per your pictures. What size brass nipple did you use and how did you mount it firmly into the carbs, Also I am assuming you only used two hoses from the primer solenoid one to each carburetor. Thanks in advance.
