Johnson/Evinrude 15hp history question...
dfrants
I purchased a 1977 Johnson 9.9hp, a buddy said if you change out the carb you can turn it into a 15hp. Which I did. Talking to one of the old service guys at the local shop told me that it really isn't a 15hp. That those older ones only produced 12hp. That I need to find a 1984 or newer one that is really a 15hp. That they opened the exhaust porting to produce the extra ponies to get 15hp...is this fact or fiction?
flyingscott
Those motors are a little lower than the newer ones but Exhaust porting was the same all the way through. The difference is the exhaust tuner and reed spacers. You can add those to yours.
Sea Rider
If both 9.9 & 15 are 250 CC should be same powerhead. Converted a 96- 9.9 HP to a 15 HP, for that needed to swap 15 HP carb , reed valve plate aasy and gaskets to work as a 15 HP. Great difference.
Happy Boating
