Johnson/Evinrude parts interchangeability
aamyot
Hi All,
I'm looking to replace the stator in my '78 Johnson 115 (model 115ETL78). I've found a local guy parting out a '89 Evinrude 120. Both are V4. Below are each of the model #'s. Could these possibly be interchangeable?
If these are not interchangeable, anyone know what years in JohnnyRude would match my '78?
Johnson #0581865 - STATOR ASSY., 10 amp.
Evinrude #0583410 - STATOR ASSY., 3/9 amp.
Thanks for all the advice,
wilde1j
Re: Johnson/Evinrude parts interchangeability
I think this is the info you need:
38 0581830 STATOR ASSY., 6 Amp. Used only on models without Power Tilt & Trim 1 $265.80 USD Legend Limited Availability
38 0581865 STATOR ASSY., 10 Amp. Used only on models with Power Tilt &Trim 1 $265.80 USD Legend Available
Info is from BRP Evinrude website.
Faztbullet
The 120hp stator will not fit as its a looper with different ignition system. If you need a used stator you need one off of a: 1978-85 115hp, 1986 110hp, 1984-87 100hp, 1984-87 90hp and 1978-83 85hp or a New one just google part #173-3672 for pricing. Pm me if you need a new one....
