Johnson Fast Strike rectifier
GunnerO
I need to replace the rectifier on my '94 Johnson 150 Fast Strike (model J150GLERA). From what I can tell, I don't need to remove the flywheel as some have said. I'd appreciate it if anyone could tell me what I need to torque the rectifier bolts to once I replace the part.
I wasn't too concerned about my tach not working and replacing the rectifier until I heard that a deficient one could start a fire. Anybody ever heard of this happening?
boobie
Re: Johnson Fast Strike rectifier
Question 1. 60-80 In. Lbs.
Question 2. Yes. After you replace the regulator put a volt meter across the battery and check the voltage when running. Should be 13.8-14.2. This is with a fully charged battery.
GunnerO
Thanks for the scoop boobie!
