Johnson Gear Oil
SteuryLover
What gear oil can be used for the fallowing motors,
61 Johnson 5.5hp
93 Johnson 88spl
93 Force 40hp
Thanks guys, I love this site.
rolmops
Re: Johnson Gear Oil
You can go to any marina and ask for lower unit oil.For all these engines it is the exact same oil.Just make sure to also ask for new sealing washers.2 for each engine.These too are all the exact same size.
In principle the lower unit oil is a hyphoid oil,usually 90 weight.
SteuryLover
Great info, thanks. The article helped a lot.
SteuryLover
Ezeke, being new to this any new information helps out a lot. As you being an Admiral, this may be old news. I did not read the charts, the article provided me with some new valuable info. Ezeke I would love to hear your input on this as you seem to have tons of experience as a Boater. I appreciate any new info.
ebry710
Ensign
Lower unit fluid seem universal. The key is the filling tube that connects to the fluid bottle and screws to the lower hole on the lower unit. It allows the unit to fill up from bottom up. Once the upper hole drips fluid you know the unit is full without air.
