Johnson J40ELCDE 1986 lower unit removal
ba_50
A manual says that the shift rod has to be disconnected at the basepan. There is a bolt set back from under the carburator that tightens a clamp on a rod. Is that it? How does it work? I would think the rod would be vertical and not horizontal to get reconnected easier. Thanks.
JUSTINTIME
Re: Johnson J40ELCDE 1986 lower unit removal
it could be
also might be on the lower unit itself
go to brp.com and look at the part blow ups
Solittle
ba 50 - FYI no need for two posts on the same subject.
