Johnson JW21E
stevehendo34
Just picked one up. Probably 1966. Probably been setting a while. What maintenance should I do? Any old Johnson manuals on line?
lindy46
Yup - 1966 Johnson 3hp.
1. Check compression - should be 65psi minimum and even across both cylinders.
2. Change water pump impeller.
3. Check coils, points, condensers, plugs, wires.
4. Clean/rebuild carburetor.
5. Change gearcase oil - check for water intrusion.
Go to the Top Secret thread at the top of the forum - it will provide you with lots of good information.
stevehendo34
Guy did whole series on it on Youtube I found.
It was crap will soaking cylinders in oil for week help, too bad it was real clean looking, but got it free.
Crosbyman
run it before calling it dead .... high numbers are great but.... you may find it an excellent troller and canoe pusher
TN-25
Low compression if present can often be fixed by resurfacing the head & replacing the head gasket. If the cylinders aren't too worn you could also give a fast scuff to the cylinder walls and install new rings; that would also help with compression. Perhaps the rings are just sticky and allowing blowby; a good old cleaning out by running a strong batch of Seafoam in the fuel might free up the sticky rings and restore compression. Try that before ripping into the motor.
