Somebody in the neighborhood left out a Johnson LD-12A 5hp (1967 I think). I took it home, and after some carb cleaning and new needle valve and seat it runs pretty good.
It needs a new prop, and for the life of me, I can't get it off. It is on a threaded drive shaft - there was a nut that came off easily, and it appears the prop should unscrew as well but I can't get it to move. I've used pb blaster and heat but it won't budge. Maybe it's hopelessly stuck.
Anybody have any experience with this motor? btw - it is a direct drive motor - no reverse or neutral. And does anyone know where I can get a prop?
Thanks
Thanks
