Johnson lower unit compatibility
juhan
Can anyone advise if the following lower units are interchangable?<br />Johnson 60hp model# J60ELCSR serial# E5287755<br />and<br />Johnson 50hp model# J50BELCDE serial# C7113566<br /><br />Kindly respond to both e-mail addresses:<br />juhan@erols.com<br />jraidma@coppin.edu<br /><br />Thank you :confused:
WillyBWright
Re: Johnson lower unit compatibility
Welcome to iboats.<br /><br />I'm not certain of the answer, so hopefully somebody that is will email you.<br /><br />If the motors have the same number of cylinders, I think they'd swap. If the 50 is a twin and the 60 is a triple, then no. Unfortunately I don't have any parts books at my disposal right now.
Dhadley
Looks like they will. Both 2 cylinder motors, both shift in the same direction, appears the splines are the same and both have the O ring on the driveshaft.
