Johnson moter sat over 30 years in garage
marinemike43
Only 15 hours on Motor
Has not been started in over 30 years,been in a Garage all the time.
60s model 50 hp 2 stroke
Whats the best steps to take .
OIl cylinders,.... take drive off before trying to move flywheel?
Thanks Mike
tx1961whaler
Re: Johnson moter sat over 30 years in garage
See the link in the "Top Secret File" post located at the top of this forum. It has the steps to go through when an outboard has been sitting.
tashasdaddy
remove spark plugs, place motor with spark plug holes up, put 1/2 ounce of marvel mystery oil in each hole, let sit overnite. in the morning turn the flywheel several revolutions, it should be smooth and easy to turn. now turn motor over and drain out excess oil. replace all fuel lines before running. http://forums.iboats.com/showthread.php?t=299680
