Johnson OB cables - SOURCE
Wildey
Moving along with the 1989 Lowe 1600 project.
This boat has a Johnson 40 with an added CMC TT unit. When the CMC was added, the control cables were evidently used from a longer boat, as the 3 had a "loop" in them :confused:. Of course, the steering cable failed. So I'm considering using the TT unit on a different hull and will need to get 3 new cables of the original OEM length for the the boat.
Looking around at many suppliers, which source would you with experience recommend ?
I see GL Skipper lists a wide selection, just checking here first.
Thank you,
W :)
Baylinerchuck
This forum is hosted by a retailer of said marine items. iBoats will have what you need. You just need to know the length of cables you want.
