Johnson OMC Seahorse
Cast-A-Way
Good morning all
I am looking at a boat that has a 1999 50 hp Johnson seahorse on it
I know that OMC made these and was wondering if they are good engines and are parts still available ?
Thank you
tashasdaddy
Re: Johnson OMC Seahorse
excellant motors, parts available.
Cast-A-Way
Thank you !
We just don't see them as much up here in canada eh !!
This one was manufactured in 1999 and looks brand new
150 on both cylinders (should be good) I guess.
tashasdaddy
i would service the water pump. on purchase just for insurance.
BUYING A USED MOTOR
overall condition, condition of the place you are buying it from, usually tells you how they care for things. compression 100 + psi, and within 10% of each other, good strong blue spark, no water in the lower unit oil. look for discolored paint, (sign of over heat at
one time, also scarred up bolts, as why. have them start it. if they fail to put it in a barrell or tank, or on muffs, or in the water, to start it they don't know what they are doing. best yet is to take it for a 30 min to 1 hour test run. also if remote controlled motor, the controls should come with
