Johnson Outboard Low Power
jtaylor
Friend has 1985 15 HP Johnson. Two days ago while under power, friend thought he had hit an object in the water because motor power dropped to about 1/2. He felt a change in his hand that was on the throttle. Full throttle only provides about half of the normal RPM. No evidence that we struck an underwater object. Again today with fresh gas and oil mixture, engine power is about 1/2 of expected power. Suggestions?
petryshyn
Re: Johnson Outboard Low Power
>check for spark at both plugs.....<br />>check compression<br /><br />*if he did actually hit something, check for sheared crank key.<br /><br />(I'm betting on the ignition)
