daveycrockett
- Joined
- Apr 8, 2003
- 1
Hi, I have a word of warning for anyone with a Johnsonrude with the Speed Limiting Overheat Warning. Before your dealer cons you into getting a new CDI box because your engine is overheating, try disconnecting the temperature switch from the head and take it out for a run. If this gives you back full throttle, then you just need a new temperature switch which is about 1/4 the cost of the CDI box. I overheated mine a few years ago because I blew the water pump impeller and was told that the CDI box goes into overheat mode and the only cure was a new CDI box. Valid information is the enemy of the slick sales pitch!
