johnson pitot question?
airframer
where can i find a pitot fitting for my '86 90 hp johnson outboard? i looked around but couldn't find a company that sold them. better just digging in a junkyard?
samo_ott
Re: johnson pitot question?
Ok, I gotta ask, what's a pitot? Must be some new fangled contraption on them thar new engines!
jameskb2
A pitot is a pressure sensor that was originally used on airplanes (still is) to determine air speed. It was adapted to boats for the same purpose.
It's a small transom mounted device with an air tube that runs to the speedometer. When the water pressure increases from forward movement, it takes that pressure up the tube to move a bladder in the speedo that in turn moves the needle for speed indication.
Most of them for boats are universal. You can find kits with tubing and hardware, or just the pitot itself at any major boat dealer / outlet.
iboats has it here: LINK Your purchase will help continue this forum's existence! :)
