wheresthefish
Thread starter- Joined
- Feb 28, 2007
- 61
hi, i am trying to remove the prop because it is bent on my johnson 15hp outboard, not sure what year it is but the silver coin on the block reads: G304050. the model number is long gone of the engine. when i removed the prop the last section of the prop stays on the shaft. it is the part with the rubber washer inset. the reason i know it is present is that i have another johnson with a similiar prop and when i removed it the entire prop housing came off. on this one it looks to be stuck on the shaft. how can i remove this and does anyone know why it didnt come off with prop? when i look at the complete prop housing that peice seems to be welded to the prop. please help....
