johnson pull start
terrybridge
Can anyone offer advise on how to string and wind recoil for a 1971 johnson 4hp? This is my first try at resurrecting an outboard. :confused:
Joe Reeves
Re: johnson pull start
(Manual Starter Cord/Spring Installation)
(This pertains to the side mount type manual starters such as the 4hp models)
(J. Reeves)
Have the rope/cord wound around the starter pulley in the proper direction and tuck the end of the cord under itself to lock it in place.
Assemble the manual starter to the engine, having the inner sping loop inserted over the related pin, BUT leave the starter spring UNWOUND and simply hanging thru the slot of the manual starter housing with the long length of the spring out side of the manual starter.
Now, using your ingenuity, rig some kind of device to force that plastic gear up into the flywheel teeth, jamming it so that it will stay engaged in those teeth.
It is now simply a matter of putting a wrench on the flywheel nut and turning it in the proper direction to pull that spring into the manual starter housing which will properly rewind it. After the spring has been pulled in completely, continue to crank it further until sufficent pressure is upon the spring. Usually three turns of the flywheel is enough.
Now, keep a firm grip on that small plastic gear so that the starter does not rewind. Using a sharp pointed scribe, pick the loose end of the starter cord free and run it out its proper exit, then attach the handle to it. That should do it.
F_R
Honorary Supreme Mariner
If you have the starter apart, do not forget to reinstall that flat washer that goes inside the spring housing.
