I recently inherited a Johnson 10HP QD-20. It has been sitting for probably 25 or more years. It was my uncle's he said it ran when he put it away. I appears to be in good shape it has been sitting a stand out of the weather throughout its time in storage. I want to get it up and running but do not know what to expect. Should I rebuild the carb? Replace the impeller? I am also going to have to convert it to a fuel pump I found a good guide as long as it will work for my motor?
http://www.duckworksmagazine.com/05/columns/max/5/index.cfm
The bottom end has grease on the outside so I am guessing that the lower unit seals have gone bad or dryed up should I go ahead and replace these also? Here are some pictures of the motor I took. Thanks a lot to all who help.
